Design Strength.
Both flexural moment and shear strength is controlled automatically according to Codes.
Dimensions of the cross-section should be satisfy Codes. It’s automatically controlled and users are warned if the rule is not satisfied.
International Design Codes
ACI 318-19 : Diaphragm Design Strength per ACI 318-19 with ideCAD
TSC 2018 : Slabs with In-Plane compressive and Shear Stresses (7.11.3) Parallel and Perpendicular Reinforcement as Collector Elements (7.11.5)
Symbols in ACI 318-19
f'c = specified comprehensive strength of concrete, psi
Ac-sh = area of concrete used to determine shear stress, in2
