With the Welded Web Connection command, column-beam connection is defined.
Location of the Welded Web Connection Command
Click the Welded Web Connection icon from the Connection menu.
The welded web connection settings dialog will open.
Location of the Welded Web Connection Settings Dialog
Type and Plates Tab
Connection plate
Connection plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Stiffeners Tab
Continuity plate
The purpose of the continuity plates is to support the column heads in the column-beam joints and to ensure the continuity of the beam head. Continuity plates are used for reinforcement in order to bend the column head and prevent column stem flow / wrinkle. If a continuity plate will be made, the option is marked. Continuity plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Web doubler plate
If the column body thickness is insufficient, web doubler plates are used to meet the shear effect of the panel area. If the web doubler plate will be made, the option is marked. Web doubler plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Plate Bolts Tab
Group 1 Bolt distance values are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Notches and Chamfers Tab
Weld access notch
If the option is selected, notching is done according to the entered values and selections. The values to be entered are shown in the schematic drawing. |
Chamfer (c1)
Chamfer (c2)
Schematic drawing
Preview
Design Data Tab
