Creating a Roof Gutter
Roof gutter command creates a roof gutter object by default, with a selected profile.
Location of Roof Gutter Command
You can access it under the 3D Geometric Objects title of the Ribbon menu, Facade tab.
Sweep Toolbar
Icons
Sweep
Draws a continuous form object according to the selected section.
Ceiling cornice
Draws a ceiling cornice object.
Baseboard
Draws a baseboard object.
Border on wall
Draws a border on the wall object.
Cordon
Draws a cordon object.
Roof gutter
Draws a gutter around the roof object.
Dome gutter
Draws a gutter around the dome object.
Parent based
Draws asweep while adhering to the contour of an object like zone etc.
Sweep operations
Opens an auxiliary toolbar with commands for changing sweep.
Section list
It is the list that allows the section of the sweep to be determined. A profile is selected from the list while drawing the object.
Profiles
Displays the folder of profiles saved in the project or to disk and allows sweep.
Settings
Displays the settings of the sweep.
  • Click the Roof Gutter icon from the Sweep toolbar .
  • The Parent Based mode in the toolbar is automatically active.
  • At the same time, the profiles to be used in the Roof Gutter object are listed in the Section box.
  • If wanted, a different profile can be selected from the Section box.
  • Move the mouse over the roof and left click.
  • Roof Gutter will form around the roof.
Bring the mouse over the roof
Creating the roof gutter by clicking the left mouse button
