Analysis settings that vary depending on the MOPC R-001 are explained in detail.
Download ideCAD for Seismic Code Design with MOPC R-001
MOPC R-001 Options Tab
Structural system type
The type of structural system for X and Y direction is selected in accordance with the design of the building. |
Response modification coefficient It is the response modification coefficient value. This row is automatically refreshed when the structural system type is chosen. |
Deflection amplification factor It is the deflection amplification factor value. This row is automatically refreshed when the structural system type is chosen. |
Redundancy factor It is the redundancy factor value. This row is automatically refreshed when the structural system type is chosen. |
ELF Ct parameter It is the ELF Ct parameter. This row is automatically refreshed when the structural system type is chosen. |
ELF x parameter It is the ELF x parameter. This row is automatically refreshed when the structural system type is chosen. |
Accidental eccentricity ratio
The eccentricity ratio to be used during the analysis is given as a percentage. |
Use custom vertical seismic load factor
If checked, the custom vertical seismic load factor which entered in "factor to use (instead of 0.2 SDS)" line is used. |
Structural system
If the building block consists of only concrete elements, Concrete; if it consists of only steel elements, Steel; Steel + Concrete option is selected if it consists of concrete and steel elements. |
Building Risk Category
Building risk category value is selected from the list according to the purpose of use of the building. |
Story drift check
Allowable story drift value is entered. |
Response Spectrum Tab
Spectrum curve
The spectrum curve resulting from the settings is shown. |
Function name The name of the spectrum function. |
Spectrum multiplier Factor of spectrum function. |
0.2 sec spectral acceleration (Ss) 0.2 sec spectral acceleration of spectrum function. |
1 sec spectral acceleration (S1) 1 sec spectral acceleration of spectrum function. |
Site class
Site class is selected. |
Short-period site coefficient (Fa) Short-period site coefficient of spectrum function. |
Long-period site coefficient (Fv) Long-period site coefficient of spectrum function. |
T0/Ts Spectrum Characteristic Periods. |
Download ideCAD for MOPC R-001
