Coupling beam dimensions cannot be less than 300 mm.
The Complete Message:
Tie beam dimensions cannot be less than 300 mm. (TBDY 2018 16.8.5.4)
This message is given for the basic coupling beams.
In TBDY 2018 article 16.8.5.4 , the minimum size of coupling beams will be 300 mm × 300 mm, it is stipulated .
Solution
  • Give the dimensions of the so-called coupling beam at least 300 mm.
  • Select coupling beam, coupling beams
  • Enter the properties.
  • In the general tab, give the width and height at least 300 mm and click the OK button.
