Transforming Closed Polygon to Polygon Section
Closed Polygon to Polygon Section command, the closed area created by the line is converted to a polygon section. With this method, sections are defined in the desired forms.
Location of Closed Polygon to Polygon Section Command
  • Create a closed area with the line.
  • Click the closed polygon to polygon section command.
  • The Section Settings dialog will open. Set your section name and material.
  • The section you define will be listed under the Sections row in the Structure Tree view .
Structure tree before polygon section is formed
Creating a closed area with a line
Selecting the area to be transformed to a polygon section
Editing the settings
Creating a polygon section and adding it to the structure tree
