Defining a End Plate Shear Connection
With the End Plate Shear Connection command, column-beam connection and beam-beam connection are defined.
Column - beam:
Beam - beam:
Location of the End Plate Shear Connection Command
  • From the Connection menu, click on the End Plate Shear Connection icon.
  • The end plate shear connection settings dialog will open.
Location of the End Plate Shear Connection Settings Dialog
Plates Tab
End plate
The end plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Top/Bottom Notch Tab
Notch
If the option is selected, notching is done according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Left flange cut
If the option is selected, left flange cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New".
Schematic drawing
Connection and source values ​​are shown on the schematic drawing.
Preview
Bolts Tab
Horizontal arrangement
Horizontal arrangement settings (number of horizontal bolt columns, distance values ​​..) of bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Bolts settings (number of lines, distance values ​​..) are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Design Data Tab
