Concrete Beam-Column Joint Design.
  • ideCAD automatically designs beam-column joints in accordance with Codes.
International Design Codes
ACI 318-19 : Concrete Beam-Column Joint Shear Design per ACI 318-19 §15, §18.8
TSC 2018 : Column-Beam Joint Design
Notation in ACI 318-19
The shear resulting from moment created by gravity load, wind, earthquake or other lateral forces at beam-column joints should be considered in the design of the joint.
