With the Roof Gutter Settings command, the alignment type, elevation, material and drawing settings of the roof gutter object are accessed.
Location of Roof Gutter Settings Command
You can access it under the 3D Geometric Objects title of the Ribbon menu, Facade tab.
General Tab
Alignment
The position of the roof gutter with respect to the roof is adjusted. The roof gutter is drawn below the height entered from the upper end of the roof eaves. |
Color Select the color of the roof gutter from the dialog that opens when clicked. |
Material
Select the material (texture) of the surfaces of the roof gutter from the drop-down list for the solid model. Texture length of the material used is entered into the texture world length. For example; If 1 is entered, the selected material texture width is taken as 1 unit and covered on the relevant walls. Considering that the texture is in the form of a square, the object surfaces are covered with 1x1 textures arranged side by side. It can be determined separately for each surface. |
Invisible edge line type Select the linetype of the background lines from the list. You can cover (invisible) any edge of the sweep. You may want to make the line types of the edges that you make invisible, different from other edges. |
Project profiles
It is a list of profiles for the roof gutter. The selected profile will be used in the enclosure. Profile preview is drawn on the right. |
Schematic section
Includes the dimensioned drawing of the selected section. |
3D preview
It is a 3-dimensional view of the roof gutter. You can rotate the image around itself by holding down the left mouse button and moving it. You can zoom in and out by holding the right mouse button and moving the mouse. |
Components Tab
Click the Add Building Component button.
In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the wall object and material size.
Roof Gutter |
Measure |
Listed |
Explanation |
Constant |
Independent |
Length |
Independent |
Length |
It means that the length of the material will be found by multiplying the length measure found when defining the material and the length of the roof gutter. |
Area |
Independent |
It means that the area measure found while defining the material will be used exactly as the amount. |
Outside area |
It means that the area measure found while defining the material will be used by multiplying it with the roof gutter outside area. |
Volume |
Independent |
The volume measure found when defining the material will be used exactly as the volume of the material. |
Volume |
It means that the volume measure found when defining the material will be used by multiplying the roof gutter volume. |
Count
Independent |
The count measure found while defining the material will be used exactly as the material number. |
Count |
It means that the count measure found when defining the material will be multiplied by the number of roof gutter. |
