How does ideCAD calculate One-Way slab design strength according to ACI 318-19?
Flexural moment is controlled automatically according to 7.5.1.1.
Dimensions of the cross-section should be satisfy ACI Eq. (22.5.1.2). It’s automatically controlled and users are warned if the rule is not satisfied.
f'c = specified comprehensive strength of concrete, psi
Ac-sh = area of concrete used to determine shear stress, in2
s = center-to-center spacing transverse reinforcement, in.
To design one-way slab under flexural moment, one-way slab design strength is provided ΦSn ≥ U. Both flexural moment and shear strength are controlled according to 7.5.1.1.
ΦMn ≥ Mu
Moment
Mn is determined according to 22.3 as nominal flexural strength Mn is calculated as shown below. Detailed information: Flexural Strength per ACI 318-19 with ideCAD
