You can automatically generate property boundaries and setback distance lines by entering coordinate values into the table. Once the property is defined, the permitted ground and total floor areas are calculated automatically based on the entered ground area ratio and total usable area ratios. When floor area polygons are defined, the project's ground area and total floor area are calculated and checked automatically.
