Built-up Area & FAR Reports
Built-up area & FAR report is created by making definitions in the zone settings in the project.
Location of Built-up Area & FAR Reports Command
You can access it from the ribbon menu, Tools tab, BUA/FAR Report title.
  • Select the existing zone and enter the zone settings.
  • From the Reports tab, select the appropriate option to include in the built-up area and to include in the FAR reports.
  • Click the Built-up Area & FAR Reports command.
  • In the Built-up Area & FAR Reports dialog that opens, enter your lot area, maximum built-up and floor area ratio.
  • It will generate the built-up area & FAR reports according to your program selections and the values ​​you entered.
Holding elections in the zones
Entering the lot area, maximum built-up and floor area ratio - For example, entering 500 for the lot area and 0.4 for the maximum built-up and floor area ratio
Generating the report
Built-up Area & FAR Reports Dialog
Lot area
The lot area is entered.
Maximum built-up area ratio
The maximum built-up area ratio is entered.
Maximum floor area ratio
The maximum floor area ratio is entered.
Printing the Report
