Concrete parameters (interval, minimum percentage, minimum stirrup interval, shearwall transverse reinforcement type, etc.) to be used in the design of concrete elements (columns, beams, slabs, shearwalls, foundations, retaining walls, etc.) are determined. Concrete design results, rebar layout, rebar diameter and interval are examined in the concrete element design dialogues and intervention is made when necessary.
General RC Settings Section -
Rebar Selection Section -
Mesh Wire Settings Section -
Column Design Settings Section -
Beam Design Settings Section -
Shearwall Design Settings Section -
Slab Design Settings Section -
Ribbed Slab Design Settings Section -
Single Footing Design Settings -
Strip Foundation Design Setting Section -
Raft Foundation Design Settings Section -
Retaining Wall Design Settings Section -
Well Foundation Design Settings Section -
Stair Design Settings Section -
Pile Design Settings Section -
Dome & Vault Design Settings Section -
Foundation Tie Design Settings Section
