Two-Way Slab Design Strength.
Both flexural moment and shear strength is controlled automatically according to Codes.
Dimensions of the cross-section should be satisfy Codes. It’s automatically controlled and users are warned if the rule is not satisfied.
International Design Codes
ACI 318-19 : Two-Way Slab Design Strength per ACI 318-19 with ideCAD
TSC 2018 : Punching Shear Stress at Critical Section (7.11.8)
Symbols in ACI 318-19
Mn = nominal flexural strength at section, in.
Msc = factored slab moment that is resisted by the column at a joint, in.-lb
f'c = specified comprehensive strength of concrete, psi
Ac-sh = area of concrete used to determine shear stress, in2
γf = factor used to determine the fraction of Msc transferred by slab flexure at slab-column connections
