Column Shear Design.
  • Column shear design and required strengths are calculated automatically.
İnternational Design Codes
ACI 318-19 : Column Shear Design per ACI 318-19 with ideCAD
TSC 2018 : Column Shear Design Forces
Notation in ACI 318-19
Av,min = minimum area of shear reinforcement within spacing s, in.2
c1 = dimension of rectangular or equivalent rectangular column, capital, or bracket measured in the direction of the span for which moments are being determined, in.
D = dead load
E = earthquake load
L = live load
Lr = roof live load
Mpr = probable flexural strength of members, with or without axial load, determined using the properties of the member at joint faces assuming a tensile stress in the longitudinal bars of at leasts 1.25fy and a strength reduction factor ϕ of 1.0, in.-lb
R = rain load
S = snow load
Ve = design shear force for load combinations including earthquake effects, lb
Veb = Capacity shear force of the column based on the maximum probable moment strengths of the beams framing into the column, lb
Vec = Capacity shear force of the column based on the maximum probable flexural strengths of the two ends of the column, lb
W = wind load
ϕ = strength reduction factor
Ωo = overstrength factor for the lateral-force-resisting system
