Transverse reinforcement detailing is applied automatically in accordance with Codes.
Transverse reinforcement detailing is applied according to Codes in earthquake resistant structure columns.
International Design Codes
ACI 318-19 : Transverse Reinforcement (CRD) per ACI 318-19 with ideCAD
TSC 2018 : Transverse Reinforcement Detailing for Columns
Notation in ACI 318-19
Ag = gross area of concrete section, in.2 For a hollow section, Ag is the area of the concrete only and does not include the area of the void(s)
Ab = area of an individual bar or wire, in.2
dagg = Nominal maximum size of coarse aggregate, in.
hx = maximum center-to-center spacing of longitudinal bars laterally supported by corners of crossties or hoop legs around the perimeter of a column or wall boundary element, in.
lo = length, measured from joint face along axis of member, over which special transverse reinforcement must be provided, in.
so = center-to-center spacing of transverse reinforcement within the length lo, in.
The spacing of transverse reinforcement is is determined automatically to meet the most restrictive requirements. uding earthquake effects is less than Agfc′/10.
