Defining a Continuous Beam Connection
With the Continuous Beam Connection command, beam-beam connection is defined. It can be applied to one piece main beam and two piece beam connections.
Location of the Continuous Beam Connection Command
  • From the Steel menu click on the line Continuous Beam Combination.
  • Click the main beam, then the beam, in the 3D perspective view.
  • The combination will occur with default settings.
Location of the Continuous Beam Connection Settings Dialog
Flange Connection Type
Top flange connection type
Connection type is selected for the top header.
Schematic drawing
Connection and placement values ​​are shown on the schematic drawing.
Preview
Plates Tab
Persistence plate
Persistance plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Shear Type Tab
Shear connection type
The shear connection type is selected.
Connection type
Welded or bolted connection types are selected.
Bottom flange connection type
Connection type is selected for the bottom flange.
Schematic drawing
Preview
Shear Plate Tab
Pressure plate
The pressure plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
General
The value is entered to determine the location of the plate according to the beam section. The values ​​to be entered are shown in the schematic drawing.
End plate
The end plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Top Left/Top Right Notch Tab
Notch
If the option is selected, notch is done according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Left flange cut
If the option is selected, left flange cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Top Left Flange Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Top Right Flange Bolts Tab
Group 1
Bolt properties
Schematic drawing
Preview
Assembly Plate Tab
Define plate geometry
If the option is selected, the assembly plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an assembly plate. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Length
The assemblyplate length to be used is determined by entering the value.
Schematic drawing
Preview
Bottom Left Flange Bolts Tab
Group 1
Bolt properties
Schematic drawing
Preview
Bottom Right Flange Bolts Tab
Group 1
Bolt properties
Schematic drawing
Preview
Design Data Tab
