Steel Column Design Settings
Steel Column Design Settings are explained in detail under this title. After completing the steel column modeling, double-click on the element to enter its properties. Two new sub-tabs, “Releases / Partial Fixity” and “Design,” appear in the steel column setting menu. These tabs contain adjustments for analysis and design.
In the Releases tab, end releases and spring values ​​can be entered at the starting and ending points of the element.
Override end releases
This command is activated by defining user-defined end releases.
I-Release
If the axial force for the starting point of the element 2-direction shear force, 3-direction shear force, torsion, 2-direction moment, and 3-direction moment are indicated, the corresponding force will be 0 at the starting point.
J-Release
For the endpoint of the element, axial force, 2-direction shear force, 3-direction shear force, torsion, 2-direction moment, and 3-direction moment are indicated, and the corresponding force will be 0 at the starting end.
Spring values - I
The spring coefficient is entered for the starting point of the element. Units can be changed by clicking the right button in the box.
Spring values - J
The spring coefficient is entered for the endpoint of the element. Units can be changed by clicking the right button in the box.
Design
The parameters used in the design are intervened in the Design tab. If a mark is placed in the box, the coefficient written in the box is used in the design. If no mark is placed in the box, ideCAD Structural automatically determines these coefficients and uses them in the design.
  • After analysis and design, the design check window is given in the “Column design → Column details” section.
