With the Brace Center Connection command, steel brace center point connection is defined.
Location of the Brace Center Connection Command
When the steel brace is defined, the program makes these combinations automatically. However, the combination made automatically can be deleted and a new one can be made.
Click the Brace Center Connection line from the Steel tab.
From the 3D perspective view, click the converging braces in turn.
The combination will occur with default settings.
Location of the Brace Center Connection Settings Dialog
Main Plate Tab
Plate dimensions
The dimensions of the plate are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Brace Connection Tab
Type (Brace)
Connection type is selected. |
Dimensions
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Bolt properties
Schematic drawing
Preview
Welds Tab
Welds
Schematic drawing
Preview
Design Data Tab
