The beam height cannot be less than 300mm.
The Complete Message:
The beam height cannot be less than 300mm. (TS500 7.3)
The following condition is given for the beam height in TS500.
Solution:
Select solid and named beams and give the beam height at least 300 mm.
  1. Select the beam, beams
  2. Enter the properties.
  3. In the general settings tab, increase the beam width and click the OK button.
