DWG/DXF/DWF Single Export
DWG/DXF/DWF Single (Export) command allows to export the drawings in the active window in the project to dwg/dxf/dwf format.
Location of the Export DWG/DXF/DWF Single
  • The story or drawing window to be saved as DWG is switched to.
  • Click the İdeCAD logo in the upper left corner.
  • Click the Export/DWG-DXF-DWF single line from the menu that opens.
  • Select one of the DWG/DXF format from the opened project save list. (* .dwg or * .dxf)
  • Write a name on the File Name line
  • The DWG/DXF Export Options dialog will open. The required parameters are set in this dialog.
  • The OK button is clicked.
DWG/DXF Export Options Dialog
Story plans mode
In the selected story plans, drawings in structural mode in architectural mode or in both modes can be exported.
Save as blocks
Objects are transferred as a block (whole). Objects come as blocks in the CAD environment.
Save as individual entities
Each line whose objects are created is transferred as a separate line object.
Save as outlines
All text in the drawing is converted to outline.
Save as autoCAD standard font
The texts used in the drawing are converted to AutoCAD's standard font (AutoCAD is a registered trademark of AutoDesk.)
Save as true type (>R13)
Text is transferred to AutoCAD R13 and higher versions as True Type
Scale fonts to make compatible with AutoCAD
When marked, the size of the texts is reduced to fit the font sizes of the AutoCAD.
Convert to nearest colors
It converts the available colors to the closest colors.
Convert to basic colors
Converts existing colors to base colors.
Black plot (CTB colors)
Turns all colors to black.
Export hatch background colors
Background colors of the hatches in the project are exported.
One dwg unit is
Unit measurement value is selected in the exported drawing.
IFC Export
