Establishing the Frame / Wing-Object Connection
Separators, lines, or extended objects are connected to crates with the Set Up Frame-Wing-Object Link command. In this way, when the safe is rotated, the connected object/objects rotate with the safe.
  • Click on the Create / Set Up Frame-Wing-Object Link line.
  • Select the safe and other objects you want to link.
ODT Materials
