Assign Material
With the Assign Material command, the texture can be assigned at once by quickly selecting a surface or element on the perspective screen, and the existing texture can be changed.
Location of the Assign Material Command
You can access it under the ribbon menu Rendering tab, Render title in the architectural program.
  • Click on the Assign Material icon.
  • The Material List dialog will open.
  • Select the material you want from the list of materials.
  • In assign mode, the material is applied by selecting the wanted surfaces/objects and clicking the assign button. In paint mode, the material is applied when the wanted surfaces/objects are selected.
  • Define your materials by selecting the desired mode and application method and selecting objects on the perspective screen.
  • After the material assignment is completed, you can exit the material list dialog by clicking the OK button.
Before assign material
Selecting the material from the material list and switching to assignment mode
Selecting the objects/surfaces to be defined as material
Completing the assignment process by clicking the Assign button
Choosing a new material and switching to paint mode
Painting the objects/surfaces to be defined as material as selected.
After assign material
Material List
List of materials
The materials in the project file are listed with their pictures.
Preview
The image of the selected material to be obtained when rendered is previewed.
Create
Opens the material editor window. New material can be defined here.
Copy
Creates a copy of the selected material.
Edit
Changes can be made to the settings of the selected material.
Delete
Deletes the selected material.
Assign
Assign materials to the selected surfaces / entities when assignment mode is active.
Mode - Assign
Assign materials to selected surfaces / objects after assigning them to them.
Mode - Paint
Applies materials to selected surfaces / objects as soon as they are selected.
Apply to - Group
Selects the clicked element as object.
Apply to - Face
Selects the clicked element as a surface.
Search
Provides easy access to the material by entering the material name in the material list.
Sort items by name
Sorts the items appearing in the list alphabetically.
Pack used textures
Saves the texture images in the material list to a selected folder.
Remove unused materials
Deletes the materials in the material list that are not used in the project from the list.
Load from library
Loads previously saved items to the list.
Material Conflict
