Flat Truss
With the Flat command, the flat truss type, which is one of the prepared truss types, si drawn quickly. Truss heights are adjusted from its settings.
Flat Truss Schematic Drawing:
Location of the Flat Command
  • Click on the flat command.
  • In the Heights tab , enter the heights h1 and h4 for flat.
Entering 80 cm for h1 and h4 in the height tab of the truss settings
Sloping Flat Truss
