Transverse Reinforcement Detailing (SwRD)
  • Transverse reinforcement detailing is applied automatically in accordance with Codes.
  • Transverse reinforcement detailing is applied according to Codes in special structural walls.
International Design Codes
ACI 318-19 : Transverse Reinforcement (SwRD) per ACI 318-19 with ideCAD
TSC 2018 : Shearwall Web Reinforcement Detailing
Notation in ACI 318-19
Acv = gross area of concrete section bounded by web thickness and length of section in the direction of shear force considered in the case of walls, and gross area of concrete section in the case of diaphrams. Gross area is total area of defined section minus area of any openings, in.2
Acw = area of concrete section of an individual pier, horizontal wall segment, or coupling beam resisting shear, in2.
ϕ = strength reduction factor
