Select Group of Objects
One of the previously created selection group is easily selected with the Select Object Group command.
Location of Select Object Group Command
After selecting an object belonging to the group to be selected, you can access the Select Group of Objects command from the menu that appears when the right mouse button is clicked .
  • Select an object belonging to the group to be selected.
  • Click the Select Group of Objects command from the right-click menu .
  • All objects in the group containing the selected object will be selected.
Selecting an object belonging to the group to be selected
Selecting the object group
