Beam Flexural Design.
  • Beam flexural design strengths are calculated automatically.
  • Beam required strengths are calculated automatically.
International Design Codes
ACI 318-19 : Beam Flexural Design per ACI 318-19 with ideCAD
TSC 2018 :
Notation in ACI 318-19
α = depth of equivalent rectangular stress block, in.
Cs = reinforcement tension force, lb
D = dead load
E = earthquake load
L = live load
Lr = roof live load
R = rain load
S = snow load
U = strength of a member or cross section required to resist factored loads or related internal moments and forces in such combinations
W = wind load
ρ = ratio of As to bd
ϕ = strength reduction factor
The beam top and bottom flexural reinforcement is designed along the beam span.
Nominal flexural strength with zero compression is calculated as follows.
From the equation of equilibrium:
Nominal flexural strength Mn:
Beam Shear Design.
