The baseboard command creates an object on the zone by default, with a selected profile.
Location of Baseboard Command
Click the Baseboard icon from the Sweep toolbar.
Sweep Toolbar
Icons |
Sweep Draws a continuous form object according to the selected section. |
Ceiling cornice Draws a ceiling cornice object. |
Baseboard Draws a baseboard object. |
Border on wall Draws a border on the wall object. |
Cordon Draws a cordon object. |
Roof gutter Draws a gutter around the roof object. |
Dome gutter Draws a gutter around the dome object. |
Free drawn Draws the sweep freely by giving a point without being attached to any object. |
Path based Draws a sweep based on the path object. |
Parent based Draws asweep while adhering to the contour of an object like zone etc. |
Wall based Draws the sweep attached to the wall. |
Story bottom aligned It automatically adjusts the level of the sweep to be the same as the story floor level and draws the object at that level. |
Story alignment free It takes the elevation of the sweep as much as the given level and draws the object at that level. |
Sweep operations Opens an auxiliary toolbar with commands for changing sweep. |
Section list It is the list that allows the section of the sweep to be determined. A profile is selected from the list while drawing the object. |
Profiles Displays the folder of profiles saved in the project or to disk and allows sweep. |
Settings Displays the settings of the sweep. |
Click the Baseboard icon from the Sweep toolbar .
Parent Based and Story Bottom Aligned modes in the toolbar are automatically active.
If desired, one of the free drawn and path based drawing modes can be selected.
At the same time, the profiles to be used in the baseboard are listed in the Section box.
If wanted, a different profile can be selected from the Section box.
Move the mouse over the zone and click the left button.
Baseboard will be formed on the zone.
Bringing the mouse over the zone
Creating the baseboard by clicking the left mouse button
