Column Combined Flexural and Axial Design.
  • Three-dimensional interaction failure surface of a column is calculated automatically
İnternational Design Codes
ACI 318-19 : Column Combined Flexural and Axial Design
TSC 2018 : Axial Force and Biaxial Moment Interaction for Columns
Notation in ACI 318-19
Ast = total area of nonprestressed longitudinal reinforcement, in2
α = depth of equivalent rectangular stress block, in.
Cs = reinforcement tension force, lb
D = dead load
E = earthquake load
L = live load
Lr = roof live load
Pn,max = maximum nominal axial compressive strength of a member, lb
Pnt = nominal axial tensile strength of member, lb
Pnt,max = maximum nominal axial tensile strength of member, lb
Po = nominal axial strength at zero eccentricity, lb
R = rain load
S = snow load
W = wind load
ϕ = strength reduction factor
εt = net tensile strain in extreme layer of longitudinal tension reinforcement at nominal strength, excluding strains due to effective prestress, creep, shrinkage, and temperature
β1 = factor relating depth of equivalent rectangular compressive stress block to depth of neutral axis
Required strength
Required strength is calculated in accordance with the factored load combinations. Combined Axial and Flexural Required strengths of a column occur simultaneously for a column. Therefore, for each applicable factor load combination specified in Codes.
Design strength
Combined nominal flexural and axial strength are calculated as shown below.
From the equation of equilibrium:
Nominal flexural strength:
