DWG/DXF/DWF Export
The DWG/DXF/DWF (Export) command allows you to export drawings in all windows in the project or drawings in selected windows to dwg/dxf/dwf format at once.
Location of the Export DWG/DXF/DWF
  • Click the İdeCAD logo in the upper left corner.
  • Click the Export/DWG-DXF-DWF line from the menu that opens.
  • In the dialog that opens, one of the dwg/dxf/dwf formats is selected from the Save as type line.
  • A name is written on the File Name line.
  • The DWG/DXF Export Options dialog will open. In this dialog, the necessary selections are made and the OK button is clicked.
DWG/DXF Export Options Dialog
Drawings
The drawings to be transferred are marked. Selected drawings are exported as separate files.
Story plans mode
In the selected story plans, drawings in structural mode in architectural mode or in both modes can be exported.
Save as blocks
Objects are transferred as a block (whole). Objects come as blocks in the CAD environment.
Save as individual entities
Each line whose objects are created is transferred as a separate line object.
Save as outlines
All text in the drawing is converted to outline.
Save as autoCAD standard font
The texts used in the drawing are converted to AutoCAD's standard font (AutoCAD is a registered trademark of AutoDesk.)
Save as true type (>R13)
Text is transferred to AutoCAD R13 and higher versions as True Type
Scale fonts to make compatible with AutoCAD
When marked, the size of the texts is reduced to fit the font sizes of the AutoCAD.
Convert to nearest colors
It converts the available colors to the closest colors.
Convert to basic colors
Converts existing colors to base colors.
Black plot (CTB colors)
Turns all colors to black.
Export hatch background colors
Background colors of the hatches in the project are exported.
One dwg unit is
Unit measurement value is selected in the exported drawing.
