With the Roof Window command, parallel windows compatible with the roof pitch are created. In order to draw a roof window, a roof is needed first.
Location of Roof Window Command
You can access the roof window command from the ODT door/window toolbar.
You can also access it under the ribbon menu Home tab Door/Window title in the ideCAD Architectural.
To define a roof window;
With the roofCreating a Roofcommand, a roof is defined.
Click the Roof Window icon in the ribbon menu .
If necessary , the appropriate window is selected in the Door/Window Settings dialog by clicking the Settings icon .
Move the mouse cursor to any surface of the roof and click with the left mouse button.
Roof window installation
Roof window
