Defining a Bolted Flange Plate Connection
With the Bolted Flange Plate Connection command, column-beam connection is defined.
Location of the Bolted Flange Plate Connection Command
  • From the Connection menu, click the Bolted Flange Plate Connection icon.
  • The bolted flange plate connection settings dialog will open.
Location of the Bolted Flange Plate Connection Settings Dialog
Type and Plates Tab
Type and plates
The distance between column head and beam section is entered. The values ​​to be entered are shown in the schematic drawing.
Flange plate
Flange plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Flange shim
Shim is a plate placed between the elements to be connected in bolted connections. If shim is to be made, the option is selected and t2, thickness value is given.
Connection plate
Connection plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Stiffeners Tab
Continuity plate
The purpose of the continuity plates is to support the column heads in the column-beam connections and to ensure the continuity of the beam head. Continuity plates are used for reinforcement in order to bend the column head and prevent column stem flow / wrinkle. If a continuity plate will be made, the option is marked. Continuity plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Web doubler plate
If the column body thickness is insufficient, web doubler plates are used to meet the shear effect of the panel area. If the web doubler plate will be made, the option is marked. Web doubler plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Plate Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value and number of bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Bolt distance values ​​are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
There is a preview of the connections. The selection made and the entered values ​​can be followed simultaneously in the preview.
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Chamfers Tab
Chamfers (c1)
Schematic drawing
Preview
Flange Bolts Tab
The horizontal arrangement settings (number of horizontal bolt columns, distance values ​​..) of flange bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Flange bolts settings (number of lines, distance values ​​..) are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Design Data Tab
