Diaphragm Design Limits per ACI 318-19 with ideCAD
How does ideCAD control diaphragm design limits according to ACI 318-19?
  • The minimum diaphragm thickness is controlled and reported automatically according to Table 8.3.1.1 for flat slabs.
  • The minimum diaphragm thickness is controlled and reported automatically according to Table 8.3.1.2 for beam-to-slabs.
αfm = average value of αf for all beams on edges of a panel
Minimum diaphragm thickness
There are two different slab thickness limits according to flat slab and beam-to-slab. According to 12.3.1.2, floor and roof diaphragms are controlled automatically in accordance with their slab type.
Detailed information: One-Way Slab Design Limits per ACI 318-19 with ideCAD and Two-Way Slab Design Limits per ACI 318-19 with ideCAD.
:check_mark:
