Beam Reinforcement Limits.
  • Longitudinal and Transverse reinforcement limits are controlled automatically.
International Design Codes
ACI 318-19 : Beam Reinforcement Limits per ACI 318-19 with ideCAD
TSC 2018 : Longitudinal Reinforcement Limits for Beams Transverse Reinforcement Detailing for Beams.
Notation in ACI 318-19
Acp = area enclosed by outside perimeter of concrete cross section, in.2
Al = total area of longitudinal reinforcement to resist torsion, in.2
Al,min = minimum area of longitudinal reinforcement to resist torsion, in.2
As,min = minimum area of flexural reinforcement, in.2
At = area of one leg of a closed stirrup, hoop, or tie resisting torsion within spacing s, in.2
Av,min = minimum area of shear reinforcement within spacing s, in.2
Tcr = cracking torsional moment, in.-lb
Tth = threshold torsional moment, in.-lb
ϕ = strength reduction factor
ρ = ratio of As to bd
