Breadcrumbs
Customize ideCAD
You can customize ideCAD according to your own style by making adjustments in the classic or ribbon menu interface. You can use the ideCAD more efficiently by reflecting your own working style to the ideCAD by making adjustments to the settings for the use of the ideCAD (toolbars, viewport configuration, view settings, background settings, project saving settings, grid system settings, etc.). You can change your settings (project settings, story settings, input units, etc.) to suit your project.
You can save the project where you made the settings and changes as a template to be used in future project work.
