What is Concrete Formwork?
Concrete Formwork is the structure, usually temporary, used to contain poured concrete and to mold it to the required dimensions and support until it is able to support itself. It consists primarily of the face contact material and the bearers that directly support the face contact material.
Notation for Concrete Formwork
fel = Mold plate bending strength [MPa]
febk = Primary support beam bending strength [MPa]
feik = Secondary support beam bending strength [MPa]
fkl = Mold plate shear strength [MPa]
fkbk = Primary support beam shear strength [MPa]
fkik = Shear strength of secondary support beam [MPa]
GK = Safety factor
p = Pressure on the formwork due to fixed and live loads [MPa]
El =Plate modulus of elasticity [mm 2 ]
Ebk = Primary support beam modulus of elasticity [mm 2 ]
Eik = Secondary support beam modulus of elasticity [mm 2 ]
Al = Plate cross-sectional area [mm 2 ]
Abk = Primary support beam cross-section [ mm 2 ]
Aik = Secondary support beam cross-sectional area [mm 2 ]
Il = Plate section moment of inertia [mm 4 ]
Ibk = Primary support beam section moment of inertia [mm 4 ]
Iik = Secondary support beam section moment of inertia [mm 4 ]
Sl = Plate section moment of inertia [mm 3 ]
Sbk = Primary support beam section moment of strength [mm 3 ]
Sik = Secondary support beam section moment of strength [mm 3 ]
bl = Formwork plate width
Lbk = Primary support beam spacing
Lik = Secondary support beam spacing
Nd = Fastener tensile capacity or strut axial compressive capacity
Download ideCAD for Concrete Formwork Design
How to Design Concrete Formwork with Detailed Calculation?
Concrete formwork Design and carrier formwork scaffolding design calculation is below:
The characteristic value is the Concrete formwork components' modulus of elasticity and strength. For the strength value, GK = 2.0 is accepted.
Primary Beam Interval, Lbk , Secondary Beam Interval, Lik , Prop Interval, Ld , Rod Interval, Lb
Primary Beam Intervals according to the selected plate thickness in slab formwork boards, beam bottom and top formwork boards, and column or shearwalls side formwork, Lbk ,
fel= Formwork plate bending strength [MPa]
fkl= Formwork plate shear strength [MPa]
GK = Factor of safety
p = Pressure acting on the formwork due to fixed and live loads [MPa]
El= Plate Modulus of Elasticity [mm2]
Al= Plate sectional area [mm2]
Il= Plate section moment of inertia [mm4]
Sl= Plate section moment of strength [mm3]
bl= Formwork plate width
For slab and column-wall formwork, bl= 1000 mm. In the beam lower formwork plates, bl is taken as the width of the beam.
Secondary Beam Intervals according to primary support beam dimensions to be used in slab, beam, column, and shear wall formwork, Lik ,
febk= Primary support beam bending strength [MPa]
fkbk= Primary support beam shear strength [MPa]
Ebk= Primary support beam modulus of elasticity [mm2]
Abk= Primary support beam cross-sectional area [mm2]
Ibk= Primary support beam section moment of inertia [mm4]
Sbk= Primary support beam section moment of strength [mm3]
Lbk= Primary support beam interval
Rod Intervals to be used in column, shearwall, and beam side formwork, Lb
feik= Secondary support beam bending strength [MPa]
fkik= Secondary support beam shear strength [MPa]
Eik= Secondary support beam modulus of elasticity [mm2]
Aik= Secondary support beam cross-sectional area [mm2]
Iik= Secondary support beam section moment of inertia [mm4]
Sik= Secondary support beam section moment of strength [mm3]
Lik= Secondary support beam interval
Nd= Rod tensile capacity or prop axial pressure capacity
The props of the slab formwork will be on each secondary support beam. Prop Intervals, Ld
pd = Pressure acting on the formwork due to fixed and live loads [MPa]
The props of the beam formwork will be on each secondary support beam.
In column or shearwall formwork, at least one level of support should be used to carry the wind loads calculated according to 1.2.2.
Wind effects are taken into account in the support design.
The Ƥd value used to determine the Prop Interval, L d, varies according to the sequential use of the scaffoldings. The total number of stories (n) where the props are used sequentially, starting from the ground story, is entered as user-defined.
If the number of primary beam, secondary beam, rod, or prop is 2, the interval values are reduced by multiplying by 0.8.
When calculating the prop interval, the total load (nG+Q) that will affect the props is increased by 10%.
Prop interval for slabs,
Prop interval for beams,
