Rigid Diaphragm Behavior
It is the assumed diaphragm to transfer horizontal forces to the structure without slab in-plane deformations.
With Rigid Diaphragm Behavior;
  • Story masses can be defined at the center of mass of the slab.
  • Since the number of unknowns is low, rapid analysis is performed.
  • Beams do not receive axial force.
Preferred building types;
  • Gapless slab structures without plan irregularities
  • Structures in which story slabs safely transfer horizontal forces to the carrier system in their own planes.
The slab is considered to be in-plane infinitely rigid and does not change shape.
  • When we compare the rigid diaphragm and semi-rigid diaphragm models, different displacement values ​​are seen in the middle region of the models.
  • The maximum displacement in the rigid diaphragm version is 0.035 millimeters.
You can review page 93 of the ideCAD Finite Elements Guide.
Diaphragm Modeling Selection
To model a rigid diaphragm, select the diaphragm modeling method from the Analysis Settings dialog.
Display of Horizontal Loads
Behavior of Structure Under Vertical Loads
