Defining a Seating Truss Connection
With the Seating Truss Connection command, column-truss connection is defined.
Location of the Seating Truss Connection Command
You can access it under the Ribbon menu, Connection tab, Experimenetals title.
  • From the connection menu, click on the Seating Truss Connection icon.
  • Select the column before the 3D perspective view and click the right mouse button.
  • Then select the truss elements attached to the column and click the right mouse button.
  • The connection will be created with default settings.
Location of the Seating Truss Connection Dialog
Seating Type Tab
Type
One of the connection types is selected from the list.
Plate dimensions
Plate dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Rollers
Roller sizes are determined by entering values.
Schematic drawing
Preview
Truss Plate Type
Connection to elements
Welded, bolted or hybrid connection type is selected for combination.
Bolted element
Become active when hybrid option is selected. The element to be bolted is determined.
Plate geometry
Element trim parameters
Element trim type options are given. Also element trim parameters are determined by entering values. The values to be entered are shown in the schematic drawing. dc settings is just for truss top connection. Adjusts the distance between top elements.
Schematic drawing
Connection and placement values ​​are shown on the schematic drawing.
Preview
Plates Tab
Cap plate
The cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Stiffeners Tab
Preliminary
The preliminary plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Secondary
Secondary plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Column
The column is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfers
The use of slope, slope type and geometric properties are determined by entering the value for easy assembly of the plates in the field.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Seating Plate Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Preview
Design Inputs Tab
