I can't get the stair drawings. Why?
In the ideCAD, straight-arm stairs can be drawn.
  • Check whether the concrete calculation axis is defined on the stair where you did not get the drawings.
  • If you do not define it, the ideCAD will not generate the drawings automatically.
  • Make an analysis after defining the concrete calculation axis.
