Frame Results of Strip Foundation
You can examine the normal force, shear force and moment values ​​on strip foundations according to the local axes of the element.
Location of Frame Results View Feature
You can access the Foundation Results tab by clicking the Analysis Model command under the ribbon menu, Concrete tab, Structural Inspection heading.
Foundation Results Tab
Show element names
If checked, the names of the elements corresponding to the elements folder in the structure tree are shown above each element.
Show local axis
If checked, show local axis of the elements are shown on the elements.
Show values
If checked, the values ​​of the diagrams will be shown on the structure.
Show units
If show values ​​is checked, it will be active. If marked, the units belonging to internal forces will be shown on the structure.
Manual scale factor
If the option is not selected, the scale factor deemed appropriate by the program is applied for internal force diagrams. If checked, the desired scale factor value can be entered manually in the box to the right.
Component
Normal force, shear force and moment values ​​occurring in foundations are displayed for any selected combination in the element local axes.
1.4G + 1.6Q Moment 3-3 diagram example in Strip Foundations
Case/combination to view
By selecting the appropriate load combination from the list, the internal forces generated in the foundations due to this combination, selected in the component tab, can be graphically examined on the structure.
Shell Results
