Changing Door/Window Opening Angles
With the Edit Door/Window Angles command, the opening direction and angle of the door and window in the 3D model are changed.
Also the opening angles of the doors/windows can be changed in the Door/Window Settings dialog.
Location of Edit Door/Window Angles Command
The ODT Door/Window toolbar that appears after the Door/ indow command is run is available in the auxiliary toolbar.
  • Click the Edit Door/Window Angles command.
  • Select the door/window whose opening angle you want to change by clicking on it with the left mouse button.
  • When you complete the selection of the door(s) for which you want to change the opening angle, click the right mouse button.
  • Enter the new opening angle in the opened dialog. The parameters here can be the opening angle or the offset depending on the type of door/window. Angle values ​​must be entered in degrees and the translation values ​​in meters.
  • Positive or negative values ​​can be used for opening directions.
  • After making the necessary changes, click the OK button to exit the dialog. Changes will be monitored in perspective.
Door window opening angle 0
Entering 45 as the new opening angle value
Door window opening angle 45
