Most adjustments to layers are made in the Layer Settings dialog. New layers are added, a single layer or all layers are turned off so that they are not visible. Layers are locked so that objects are not affected by operations.
Location of the Layer Command
You can access the layer command from the Settings tab, Settings heading.
Layer Settings Dialog
Layer name
The layers in the project are listed. |
Visible
Whether the relevant layer is open or hide is determined by ticking the box. |
Locked
Whether the relevant layer will be locked or not is determined by ticking the box. |
Hide empty layers on toolbar By ticking the option, only used layers are listed in the toolbar. |
Apply to current drawing only Changes made are applied only to the active page. |
Apply to all stories Changes made are applied to all story pages. |
Apply to all drawings Changes made are applied to all drawings. |
Use for new drawings Changes made will apply to newly created drawings. |
New Adds a new layer. |
Erase Erases the selected layer. |
Show all Shows all layers at once. |
Hide all Hides all layers at once. |
Unlock all Unlocks all layers at once. |
Lock all Locks all layers at once. |
Show/hide imported layers Turns only the layers of the imported drawings show or hide. |
Unlock/lock imported layers Locks or unlocks layers of imported drawings only. |
Remove unused layers Removes unused layers in the project. |
