The edit slab edge command is used to set offset distances from the edges of steel slabs.
Location of the Edit Slab Edge Command
Click the Edit Slab Edge icon from the toolbar .
Select the slab edges you want to edit.
Click the right mouse button to finish.
In the window that opens, enter the offset distance.
Click the OK button.
Before edit slab edge
Selecting the slab edge to be offset
Entering offset distance
After edit slab edge
