Joint Shear Strength.
  • Beam-column joint shear force and joint design shear strength are calculated automatically.
  • Beam-column joints of earthquake resistance structures are automatically designed in accordance with Codes.
International Design Codes
ACI 318-19 : Joint Shear Strength per ACI 318-19 with ideCAD
TSC 2018 : Column-Beam Joint Shear Design
Notation in ACI 318-19
Aj = effective cross-sectional area within a joint in a plane parallel to plane of beam reinforcement generating shear in the joint, in.2
db = Nominal diameter of bar, wire, or prestressing strand, in.
Mpr = probable flexural strength of members, with or without axial load, determined using the properties of the member at joint faces assuming a tensile stress in the longitudinal bars of at leasts 1.25fy and a strength reduction factor ϕ of 1.0, in.-lb
(Vu)j = required joint shear force, lb
ϕ = strength reduction factor
