Diaphragm Required Strength per ACI 318-19 with ideCAD
How does ideCAD calculate diaphragm required strength according to ACI 318-19?
  • Rigid and semi-rigid diaphram conditions should be choosen by user according to irregularities defined in ASCE 7/16.
  • Analysis is done automatically according to finite element method.
The required strength is designed to analyze Load Factors and Combinations per ACI 318-19 with ideCAD. It’s important to determine the required strength of diaphragms to control the effects of out-of-plane loads simultaneously with other applicable loads.
Diaphram modeling and analysis
The analysis is done automatically according to the finite element method. Rigid and semi-rigid diaphragm conditions should be chosen by the user according to ASCE 7/16.
:check_mark:
