One-Way Shear Strength.
  • Shear strength is calculated automatically
İnternational Design Codes
ACI 318-19 : One-Way Shear Strength per ACI 318-19 with ideCAD
TSC 2018 : TSC One-Way Shear Strength
Notation in ACI 318-19
Ac-sh = area of concrete used to determine shear stress, in2
fc ' = specified compressive strength of concrete, psi
(fc')0.5 = square root of specified compressive strength of concrete, psi
Nu = factored axial force normal to cross section occurring simultaneously with Vu or Tu; to be taken as positive for compression and negative for tension, lb
ϕ = strength reduction factor
λ = modification factor to reflect the reduced mechanical properties of lightweight concrete relative to normal weight concrete of the same compressive strength
λs = factor used to modify shear strength based on the effects of member depth, commonly reffered to as the size effect factor
Nominal one-way shear strength at a section, is calculated by using concrete and transverse reinforcement properties.
