Trapezoid Type 2 Truss
With the Trapezoid Type 2 command, the trapezoid truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Trapezoid Type 2 Truss Schematic Drawing:
Location of the Trapezoid Type 2 Command
  • Click on the trapezoid type 2 command.
  • In the Heights tab , enter the heights h1 , h2 and h4 for trapezoid type 1.
Entering 80 cm for h1 and h2 and 140 cm for h4 in the height tab of the truss settings
