Rebar Selection
With the Rebar Selection command, the rebar diameters to be used in the concrete design are selected. Reinforcement diameters selected from the Rebar Selection dialog are used in the design of concrete elements (column, beam, shearwall, slab, foundation, pile, retaining wall, etc.) .
Location of the Rebar Selection Command
Ribbon menu Analysis and Design tab Reinforcement title under Rebar Selection you can reach the command.
  • Click on the concrete element tab that you want to change the rebar.
  • Mark therebar diameters you want to use in the project with the left mouse button.
  • According to the selection made after the analysis, the rebars are used in the concrete design of the elements.
  • Unmarked rebars are not used in the concrete design of the elements.
Rebar Selection
Rebar Types
Rebar ID
Rebar types are listed.
Diameter
The diameter values ​​of the rebar types are listed.
Area
The area value of the rebar types are listed.
Type
The types used in rebars are listed.
Load SI rebars
Rebars of SI rebar type are loaded.
Load US rebars
Rebars of US rebar type are loaded.
Load US metric rebars
Rebars of US metric rebar type are loaded.
Load Canadian rebars
Rebars of Canadian rebar type are loaded.
Load Australian rebars
Rebars of Australian rebar type are loaded.
Add new custom rebar
Rebars of different diameters can be added. The Add New Custom Rebar dialog opens. The diameter and rebar id are entered, and the type is selected.
Delete selected rebars
Deletes the selected rebar from the list.
Move up
Move up the selected rebar in the list.
Move down
Move down the selected rebar in the list.
Column
Rebar ID
Diameter
Location of rebar and selection boxes
The location and dimensions of the listed rebars are selected by checking the boxes.
Beam
Rebar ID
Diameter
Shearwall
Rebar ID
Diameter
Sub Basement Shearwall
Rebar ID
Diameter
Slab
Rebar ID
Diameter
Rib-Waffle
Rebar ID
Diameter
Strip Foundation
Rebar ID
Diameter
Raft Foundation
Rebar ID
Diameter
Single Footing
Rebar ID
Diameter
Foundation Tie
Rebar ID
Diameter
Stair
Rebar ID
Diameter
Shell
Rebar ID
Diameter
Pile
Rebar ID
Diameter
Retaining Wall
Rebar ID
Diameter
Well Foundation
Rebar ID
Diameter
Mesh Wire Settings
