Bolt size, bolt grade and bolt hole type are determined for bolted steel connections with the Hole & Bolt Parameters dialog. Any connection with bolts has this dialog in the connection settings.
Round hole
One of the normal, oversize or custom round hole types is chosen. If a custom round hole type is selected, the wanted value can be given. |
Slotted hole
One of the short, long or custom slotted hole types is chosen. If a custom slotted hole type is selected, the wanted value can be given. |
Bolt size
Bolt size is selected from the list. |
Bolt grade
Bolt grade is selected from the list. |
