With the 3D Isometric View Drawings command, 3D isometric drawings of the columns/walls, beams and slabs of the formwork scaffolding of the active story are created.
Location of the 3D Isometric Drawings Command
You can access it from the Drawings tab under the Create Drawing heading.
Click the formwork drawings icon. The formwork scaffolding drawings dialog will open.
In the dialog that opens, click the 3D Isometric Drawings button.
3D isometric drawings of columns/walls, beams and slabs of the formwork scaffolding of the active story will be created.
Example 3D isometric view drawings |
Column formwork scaffolding 3D isometric view drawing
Beam formwork scaffolding 3D isometric view drawing
Slab formwork scaffolding 3D isometric view drawing
